2005 Isuzu Ascender drl disabling
61,444 MILES • V8 • 4WD • AUTOMATIC
DEVIATEUS
Hello I need help disabling My DRL. I have issues because I had HID installed. I found out it is because of the DRL's. Can you tell me how to disable them? There is no dedicated fuse or anything simple I can do. I assume I will have to jumper a wire or just disconnect one?
Jul 26, 2009 at 2:45 PM
RACEFAN966
  • 5,029 POSTS
Ok there is no way to disable the DRL on you car. It is tied into the light switch and the body control module and computer system and it part of the entire system not seperate at all. Now with some cars the owners manual will tell you how to program it for on or off if the manufacture has set that feature in. Sorry but if you saw the wiring diagram on this you would see what I mean it is just simply built into the body control module and light switch as a unit with the entire lighting system.
Jul 28, 2009 at 3:08 AM
