2004 Isuzu Ascender Fuel check valve leak
90,000 MILES • V8 • 2WD • AUTOMATIC
JENPHI2
The check engine light is on and the dealer sya that the Fuel check valve is leaking. That the Gas tank must be replaced for $980.00. Is the check valve installed in the tank? or is the filler hose cracked and leaking requiring tank removal?
Feb 16, 2010 at 3:04 AM
DOCFIXIT
  • 18,828 POSTS
There is a Technical Service Bullitin on leaking check valve Isuzu will warranty for 10 yrs or 150K miles. Refer to TSB SBo7-02-202 applies to VINlast 7 digits starting 3210001 to 46119613.For more info call isuzu 1-800-255-6727 refer to TSB.
Feb 16, 2010 at 4:58 AM
