2004 Isuzu Ascender Car Stalls
KIRSTYBERGY
Engine Mechanical problem
2004 Isuzu Ascender 6 cyl 55,398 miles
I just replaced the battery on my car because it was not holding a charge (the battery). Today when I was driving the car, every time I stop and the air is on the car dies. If the air is off the car stays on. It only dies when the car is idling and the air is on. Please help. Thank you
Oct 25, 2008 at 10:57 AM
KHLOW2008
  • 41,812 POSTS
Hi kirstybergy,
Thank you for the donation
The problem you are facing should be the idliong speed is too low and the idle booster is not compensating when AC is turned on.
You have just replaced the battery and when power is disconnected, the engine computer (ECM/PCM) memory has been erased and you need to let it relearn before it can work efficiently.
1. Start engine and let it warm up with no load till operating temp is achieved , eg, lights, AC etc all OFF
2. Turn on AC and let it idle till the speed is stable and you shold be ready.
If the above does not help, then you might need to clean the throttle body and Idlie Air Control. Clogging of air passages would reduce air flow and cause the idling spped to be low and stalling.
Oct 25, 2008 at 6:28 PM
