slow shifting between second and third gear with engine revving excessively
163,000 MILES • AWD • AUTOMATIC
M_J_C
  • 12 POSTS
Car takes a while to shift between second and third gears. Car also revs excessively when changing gears. For instance, when I am on the highway I will accelerate to sixty mph and the car revs loud at 4,000 rpm. If I relieve pressure on the gas pedal and then immediately apply it again, it then shifts gears and the rpm's drop to normal. When I am slowing down from highway speeds it will jerk as its de-accelerating from third to second gear.
I realize this is likely transmission related. But I am hoping there could be an easier solution? Throttle body dirty? Spark plugs? Thanks
Jul 5, 2017 at 1:18 AM
  • 55,684 POSTS
It sounds like you have a shaft speed sensor that has gone out, please run the codes to confirm. Here are a couple of guides to get you started in the right direction.
and
https://youtu.be/f3bETtCIdxM
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 7, 2017 at 5:01 AM
M_J_C
  • 12 POSTS
Thanks Ken. Drove the car yesterday and it was noticeably worse. Jolting when shifting through gears. Got a check engine light and the codes were: 62-1, 83-1, P0685.
Hoping its just a battery cable or pcm relay. Ended up taking it to a mechanic with proper diagnostic tools (and for a separate issue). Will update when solved.
Jul 7, 2017 at 7:11 AM
  • 55,684 POSTS
Cheers, Ken
Jul 7, 2017 at 1:01 PM
M_J_C
  • 12 POSTS
At the moment this is thought to be a bad battery. Trying the new battery for now -- so far so good. Possibility that its a bad starter. Mechanic also suggested I have the software updated at a Honda dealer (this is a 2005 - is this really necessary? Also -- how can I find out if I have the most up-to-date software already?) Will update this as things progress.
Jul 12, 2017 at 12:00 PM
  • 55,684 POSTS
Cheers, Ken
Jul 13, 2017 at 8:50 AM
M_J_C
  • 12 POSTS
I had the battery replaced and the problem is now worse. When driving, I get a noticeable shudder between 1st and second gears (or a jolt when it switches). Today while this happened it was accompanied by a click sound from the passenger side (fuse box?) until at one point the wheel froze up and it went into limp mode. I'm worried now that this is a problem with my PCM. Could a faulty fuse or relay in the passenger side fuse box cause my car to shudder between gears? Or cause it to go into limp mode? Thanks
Jul 13, 2017 at 9:30 AM
  • 55,684 POSTS
It sounds like a speed sensor, please scan the computer for codes.
Jul 13, 2017 at 10:20 AM
M_J_C
  • 12 POSTS
The code I have is P0685.
Question: If it is a bad relay (PGM-F1), do I need to disconnect the battery when I check the relay? Or if I replace it? Also -- if it is a ground wire (G101 perhaps) - do I need to disconnect the battery to remove the ground to clean it? Or can I do all of this while the battery is attached? I am trying to troubleshoot small things before I bring it back to the shop. Thanks
Jul 14, 2017 at 12:25 AM
  • 55,684 POSTS
Yes it could be a bad PGM relay which is a common problem. check the relay with the battery connected and clean the ground and positive to the battery
Please let us know what you find.
Cheers, Ken
Jul 14, 2017 at 2:41 AM
