Issues starting
136,000 MILES
FMFPATRIOT
I have a 2004 impreza outback. Recently it developed a starting problem. It will turn over and over and over but won't actually fire. The only success I've had is with spraying starting fluid in the intake then it fires hesitantly and runs fine after that. It's not the battery or the starter, I replaced the fuel pump so it has to be something with fuel initially I would guess?
May 6, 2013 at 2:22 PM
RANDICO
  • 174 POSTS
You have a ECT (engine coolant temperature sensor) that can do it, Does this happen after a cold soak?
May 6, 2013 at 2:40 PM
FMFPATRIOT
No its been dry since this started. After some research I'm leaning towards the cam sensor or crank sensor, it doesn't do it on cold starts, just when its been off for an hour or so.
May 6, 2013 at 3:11 PM
  • 31,937 POSTS
Check fuel pressure is ok, check injection pulse, and check coolant temp sensor, not the temp sender for the gauge.
May 6, 2013 at 8:50 PM
