Intermittent transmission not shifting properly?
308,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
LOWRIDERLICOLN
It doesn't do it all the time but when you are going down the road it seems not to shift properly, no codes but for a p420, but when it does it you can stop, cut the van off and start it back up and it's fine, when sitting it seems to idle to 1,000 RPMs.
Jul 27, 2022 at 10:40 AM
  • 110,251 POSTS
Are you referring to the transmission when you say slipping? If so, have you checked the fluid level and condition of the transmission fluid?
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
As far as the P0420, chances are the catalytic converter is bad. However, let's focus on one thing at a time. Let me know which issue you would rather start with.
Take care and I'll watch for your reply.
Jul 27, 2022 at 1:28 PM
LOWRIDERLICOLN
The fluid is fine, it's clean, it doesn't do it all the time and when it does you have to pull over cut the van off and start it back up and it's fine.
Jul 27, 2022 at 1:43 PM
  • 110,251 POSTS
That's interesting. I say that because if the clutches are worn and causing it to slip, restarting it wouldn't change that. Is the P0420 the only code you ever had? I ask because I'm questioning if there is a code related to the transmission. It sounds like a pressure-related issue. You may want to consider having the can-bus scanned to see if there are codes.
CAN stands for controller area network. Basically, the different computers/modules are tied together via a few wires. This can retrieve codes regardless of the module storing them.
Here is a link showing how it's done:
Let me know if this is something you have already done.
Jul 27, 2022 at 3:20 PM
LOWRIDERLICOLN
Yes, and the only code is p420 which is that cat o2.
Jul 27, 2022 at 3:44 PM
  • 110,251 POSTS
The P0420 indicates the catalytic converter is operating under the threshold. In most cases, it is the converter and not the O2 sensor.
As far as the slipping, the best thing to do is a line pressure test to confirm there isn't a low-pressure issue resulting in the slipping. There is a pressure control solenoid mounted in the valve body that may be failing.
I attached pics of the sensor I'm referring to.
See pic below.
Jul 28, 2022 at 5:54 AM
