Issues following clock spring replacement
150,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
KENNETH GRIFFITHS
Auto electrician changed clock spring which turned off airbag light however this has caused other problems with my ABS brakes applying randomly and also the ESP (traction control) doing the same.
Apr 5, 2021 at 11:05 PM
BORIS K
  • 836 POSTS
For more accurate diagnostic support I would suggest to have the vehicle scanned for fault codes . Once you have those DTC codes please post them so that we can evaluate these and give you a proper reply.
Please let us know how you get along.
Cheers, Boris
Apr 6, 2021 at 9:14 PM
  • 55,749 POSTS
This sounds like the wheel speed sensor could be out. To be sure lets do a CAN scan which is the future of automotive repair. you can get a CAN scanner from Amazon for about $50.00. here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Or you can try this guide.
Apr 7, 2021 at 11:18 AM
