Issue of vibration
183,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
ZAHIRNIZAR
I have the vehicle listed above T30 model. it gets a vibration when the gear is engaged and also the vibration increases if the AC is on. Why does it happen? please give some solution if possible.
Jan 30, 2019 at 12:28 PM
SEVAG P
  • 405 POSTS
As a first step check engine mounts and transmission mounts.check visually if any hydraulic oil leak from them or the rubber is deformed (cutted).
Jan 31, 2019 at 2:15 AM
  • 55,743 POSTS
Also, if you could remove the serpentine belt and then start the engine to see if the vibration is still there? Here is a guide to help walk you through the steps:
https://www.2carpros.com/articles/replace-serpentine-belt
Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
Jan 31, 2019 at 8:39 AM
