Isolating a bearing noise (front)
70,000 MILES • 1.7L • 2WD • AUTOMATIC
NEIL2002CIVIC
  • 119 POSTS
Hi, one bearing is staring to hum going into a turn doesn't change the noise. The tires are good with no cupping. I'm disabled but was a mechanic for many years. That being said what is the easiest way to isolate the noise? Although I believe it's the left front. please include checking the rear also. I shook all the wheels no play is felt. I have been told you can spin the wheel and hold the spring. By doing that i'm told you will feel the roughness of the bearing and none if it is good. Is that true or not? I do have an electric ear I can use also. please keep in mind my flexibility is limited (need hip replaced).
Jul 27, 2020 at 2:53 AM
If you have chassis ears then this is the best way to find it. Once you narrow it down to a specific area, using a mechanics stethoscope with the vehicle on jack stands will be how to pinpoint it.
Unfortunately holding the spring is not definitive unless the bearing is so bad that it is felt this far away.
I would suggest just starting with the chassis ears and going from there. Here are some guides that will help:
https://www.2carpros.com/articles/vehicle-grinding-noise
https://www.2carpros.com/articles/car-howling-noise
Jul 27, 2020 at 8:10 AM
NEIL2002CIVIC
  • 119 POSTS
Okay thanks. Just 1 quick thing. I know it will throw an ABS light when i spin the front wheels up in the air. Correct me if I'm wrong it should go out once i drive and the computer sees all wheels moving again. Thanks, stay healthy!
Jul 27, 2020 at 8:54 AM
Correct. If you had the key on it can throw a wheel speed code. Once you drive it that will go away. If not, we should check the code just to find out what it is.
Jul 27, 2020 at 12:09 PM
