The engine is sluggish, and it vibrates in idle while in park and drive, is this a leak?
164,000 MILES
JAYJOHNSON0318
  • 40 POSTS
I'm trying to figure out why my car is so sluggish and it's vibrating in idle while in park and drive. The engine is loud when accelerating. i have to press down on my gas hard for my car to even go past 40 MPH. Then I looked under my car and seen this? Could this be the problem?
Jan 15, 2024 at 1:08 PM
  • 55,746 POSTS
Hello, and thanks for the video. Yes, you do have a coolant leak, so please be careful. Allow the engine to cool down before you check the coolant level and do not drive the car until it is fixed, or you might ruin the engine.
This video will help:
https://youtu.be/GSE9skKnOgY?si=ycd62fnfGWg0YZc1
It is difficult to tell here is it coming from by the video, but it looks like it is the radiator which is common. If you raise the hood and look you might be able to see where it is coming from.
This guide can help:
https://www.2carpros.com/articles/car-is-leaking-coolant
To change out the radiator you will need to discharge and refill the A/C system.
This guide will show you what needs to be done in case of a radiator change:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jan 16, 2024 at 2:20 AM
JAYJOHNSON0318
  • 40 POSTS
That video is the back of my car by the muffler. not the front. Isn't the radiator in the front of the car?
Jan 16, 2024 at 3:19 AM
  • 55,746 POSTS
Sorry I couldn't tell if it was the front or the rear. If water drips from the exhaust system this is normal until the engine gets hot. I would wait until the engine is cold though and check the coolant level.
Please go over this video to help:
https://youtu.be/GSE9skKnOgY?si=ji0ufI3dpNdTF1Td
Please start a new thread for your other problems so we can help you.
Jan 17, 2024 at 1:30 AM
JAYJOHNSON0318
  • 40 POSTS
I live In MN and it's cold. I recorded that video when my engine was already warm. Could there be a problem with my exhaust?
Jan 17, 2024 at 2:49 AM
  • 55,746 POSTS
No, it is just condensation for the engine which is normal, was the coolant level low?
Jan 18, 2024 at 2:28 AM
