Is this a battery or a starter issue?
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARPUP
When my fob didn’t open doors, I knew it was off. After I used my keys to open the door, I realized dome light was left on “on” position for last 3 days maybe I hit it. There were no dash lights, etc. So, I thought I just needed to use my 12v jump box to recharge battery. After letting it sit connected for 15-20 minutes, I turned key one stop and got dashboard light, etc. When I turn the key to ignite, I get quick burring/clicking sounds and dash lights sputtering too. I tried it a couple more times and would also just get a loud, clear clicking sound when I turn the key to ignite. If I didn't know dome light was left on for 3 days. I would have thought this a clear starter problem (refurbed starter 1 year ago and new battery).
1. If I hook up my 12v jump box longer will that be enough? If so, how long should I l have it connected?
2. Do I need a car-to-car Jump? (For a bigger jolt?)
3. Do I need to hook it up to an actual battery charger? For how long?
4. Do I need a new starter?
Dec 14, 2022 at 5:11 PM
  • 55,649 POSTS
The jump box is not strong enough to jump a completely drained battery. I would try a car-to-car jump. This video will show you how, once running allow the engine to run for a couple of hours, this should be enough to recharge the battery.
https://youtu.be/a9Ycibu9cwY
Please go over this guide and report back.
Dec 15, 2022 at 6:59 AM
CARPUP
Thanks for your response, Ken. What is my next step if car-to-car jump doesn't work? Battery charger, or instead, can I use one of the smaller, quicker lithium-ion packs to bring a discharged car battery back?
Dec 15, 2022 at 1:52 PM
  • 55,649 POSTS
If a car-to-car jump doesn't work replace the battery with a new unit. Here are the instructions in the diagrams below with a generic guide to show you step by step what to do:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Dec 16, 2022 at 4:29 AM
