VVT solenoid location
145,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
DANI1983
I was having problems with my vehicle where it would chug a bit, then the traction control light would come on. I had to pull over let it sit for a minute so the traction could reset itself. I had an original code on my car PO449, we changed the gas cap and the purge valve canister (i think it's called), then threw another code for the crank shaft sensor, fixed that. Threw a code for the cam shaft position sensor, fixed that, checked all the wires and harnesses on each. Then wouldn't start at all after we replaced the crank shaft sensor. It sounded like the timing was off as we were trying to crank it over. So we looked it up and the internet said possibly the Variable Valve Timing solenoid (VVT), but we can't seem to find where it is at. Does anyone know where it's located, or if they think it could be something else? Any help is appreciated.
Aug 20, 2020 at 8:18 AM
Good evening,
What were all the code numbers? Codes rarely identify bad parts, just failed systems.
https://www.2carpros.com/articles/how-camshaft-variable-valve-timing-works
The fact you have both cam and crank sensor codes, it indicates to me a timing issue between the valves and the piston.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
I would start with a compression test as I think you have a bad timing chain.
Aug 20, 2020 at 9:08 AM
DANI1983
The codes that I have had so far, if I remember correctly, we're P0449, U0073, P0339, P0336, P0341. (Not in any specific order) I can't do the compression test though because the engine won't turn over. It hard chugs as it tries to start, but won't turn over. It sounds like the timing is off.
Aug 20, 2020 at 10:25 AM
DANI1983
and thank you for your fast reply!!! :-)
You are welcome.
Yep, that is what happens when the chain moves.
Remove the spark plugs and see if it cranks over.
I attached the code possibilities for you. The 2 codes have the timing chain in common.
There is no 339. Can you verify?
U0073 is a serial data line or communication line code.
DTC U0073 or U2100
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. See: Vehicle > Initial Inspection and Diagnostic Overview
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptor
DTC U0073 00
Control Module Communication Bus Off
DTC U0073 71
ECU HS Bus Off
DTC U0073 72
ECU LS Bus Off
DTC U2100 00
Controller Area Network (CAN) Bus Communication
DTC U2100 47
Circuit/System Description
The serial data circuits are serial data buses are used to communicate information between the control modules. The serial data circuits also connect directly to the data link connector (DLC).
Conditions for Running the DTCs
Supply voltage at the modules are in the normal operating range.
The vehicle power mode requires serial data communications.
Conditions for Setting the DTC
The module setting the DTC has attempted to establish communications on the serial data circuits more than 3 times.
Action Taken When the DTCs Sets
The module suspends all message transmission.
The module uses default values for all parameters received on the serial data circuits.
The module inhibits the setting of all other communication DTCs.
Conditions for Clearing the DTC
A current DTC clears when the malfunction is no longer present.
A history DTC clears when the module ignition cycle counter reaches the reset threshold of 50, without a repeat of the malfunction.
Circuit/System Verification
1. Refer to Data Link References to determine which serial data system is used for a specific module. See: Information Bus > Initial Inspection and Diagnostic Overview > Data Link References
2. This DTC cannot be retrieved with a current status. Diagnosis is accomplished using the symptom Scan Tool Does Not Communicate with High Speed GMLAN Device or Scan Tool Does Not Communicate with Low Speed GMLAN Device.
Aug 20, 2020 at 10:41 AM
DANI1983
That code should have been the crankshaft position sensor. I will try that tomorrow when I go over there to work on it again. Thank you so much for your input. We've been going crazy trying to figure this one out.
Aug 20, 2020 at 2:37 PM
4DRTOM
  • 467 POSTS
Hi I'm Tom,
The VVT solenoid will be at the head of the cam shaft. You should be able to see two wires leading in somewhere there.
Tom
Aug 20, 2020 at 3:58 PM
Do your compression test first before replacing anything as I think you have an issue far beyond the VVT solenoids. I would not like to see you throw expensive parts at it to find out you need major engine work.
Aug 20, 2020 at 8:44 PM
