Is there a way to check the ECM computer for proper voltage
234,789 MILES • 2.8L • V6 • 2WD • MANUAL
SCKMYJUNK
I bought a 1991 Chevy S10 pickup 2.8 liter V6 2 wheel drive she started blowing the fuse to the ECM I replace the fuel pump fuel relays the injector plugs I also found a chafed wire by the oil pressure switch I fix that now I'm only getting 8 volts to the fuel pump
Aug 24, 2016 at 10:19 AM
WRENCHTECH
  • 20,760 POSTS
The power supply for the fuel pump doesn't come from the ECM. It only supplies ground trigger for the relay. https://www.2carpros.com/images/external/41927760.gif
Aug 24, 2016 at 11:37 AM
