Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Maxima
Exterior Light
Turn Signal
is there a way to "turn off"check engine indicator light
1995 NISSAN MAXIMA
260,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOE WHATLEY
MEMBER
1 POST
I need to "Turn off"check engine indicator LED. How do I do this?
Jun 24, 2020 at 3:41 AM
Experienced Mechanic
The short answer is yes, but that requires you fixing the issue that is causing the light to turn on.
Let's start with checking what the code is so we can find out what is causing the light to come on and we can go from there. Thanks
Here is a guide that will help with this. Let us know what you find.
Jun 24, 2020 at 4:01 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
