is there a way to "turn off"check engine indicator light
1995 NISSAN MAXIMA
260,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOE WHATLEY
I need to "Turn off"check engine indicator LED. How do I do this?
Jun 24, 2020 at 3:41 AM
The short answer is yes, but that requires you fixing the issue that is causing the light to turn on.
Let's start with checking what the code is so we can find out what is causing the light to come on and we can go from there. Thanks
Here is a guide that will help with this. Let us know what you find.
Jun 24, 2020 at 4:01 AM
