Transmission is in limp mode
99,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JIMSTAT
Transmission is in limp mode and checking for power.
Is there a relay for the transmission on the vehicle listed above it is the 2500 and if so where is it located?
Oct 31, 2017 at 3:22 AM
  • 110,246 POSTS
The vehicle has a transmission control module. I believe it is under hood near the power distribution center. Before dealing with that, check for trouble codes. The OBD 1 system should point you in the right direction.
Oct 31, 2017 at 12:21 PM
