Hello, I'm Danny.
If you are going to unplug the radio I would do so with the radio turned off. As far as the only problem I foresee is that some car makers with their factory(stock) radios will sometimes require a radio code when the factory radio is plugged back in or reinstalled to get to work again.Hope this helps and thanks for using 2CarPros.
Apr 30, 2020 at 12:04 PM
