Is the radiator drain plug replaceable
90,000 MILES
MMCSAK
While replacing thermostat, upon closing drain plug, the bolt head part broke off. It is closed, and not leaking. Just wondering if this is a replaceable part, or if a new radiator will be required to have a working drain plug.
Aug 6, 2019 at 11:56 AM
SCGRANTURISMO
  • 4,897 POSTS
It is a replaceable part. You should be able to take a wide headed screw driver and put it in the petcock hole and unscrew the petcock that way. Just unscrew it out and put a new one in. Please get back to us with how it turns out.
Thanks,
Alex
2CarPros
Aug 6, 2019 at 12:33 PM
