Is power sent to unused wires
2008 FORD ESCAPE
125,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
CR4M0013
I am making a modification to my car and I am wondering if power is sent to unused wires. In my vehicle, there is an upgrade to have a compass, but mine does not have it. Upon removing the panel where the control buttons would be I found the wire. I am wondering if the power is still being sent to that plug even though I don't have the compass feature.
Apr 25, 2019 at 3:04 PM
SCGRANTURISMO
  • 4,897 POSTS
More than likely it is. A simple way to find out would to measure it with a multi-meter with your vehicle running. You might want to turn your headlights on as well, as I suspect this to be a connector for a light for the compass. I have included a link below that will explain how to use a multi-meter if you are unfamiliar with how to use one below.
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Apr 25, 2019 at 4:33 PM
