is oil change at 5K or 3K and i do use synthetic oil. please help.
2013 MAZDA 3
20,200 MILES • 4 CYL • 2WD • AUTOMATIC
DENISEBARNES
MEMBER
1 POST
when do i change the oil?
Jan 15, 2015 at 12:35 AM
HMAC300
✓Experienced Mechanic
5k is ok and change filter as well. Synthetic is better oil and would be changed at 7-10 k intervals. it is more expensive however an dif you switch to synthetic you will see some oil usage at first which is normal.
Jan 15, 2015 at 1:30 AM
