Is my transmission leaking?
112,350 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
LASHAWN STAPLETON
I’m seeing dried up fluid on the back part of the transmission and don’t know if it’s leaking or not. I bought the car in May 2020 and had a minor accident but no transmission damage, so I don’t know if it’s had that issue since I bought or a while after.
Jan 28, 2022 at 8:35 AM
SQM
  • 6,383 POSTS
So, do you see any fluid on the ground?
Is the fluid level correct?
Usually if the fluid is leaking for some time, you will have a low fluid level.
Also, it can drip on the ground.
To find out if this is an active leak, just clean out the fluid residue and check it after a drive or two, to see if it appears. If you are unable to see any fluid, then it is likely not a leak.
If your fluid level is correct, then it is possible that it is not an active leak.
Let me know if you have any questions.
Jan 28, 2022 at 11:31 AM
LASHAWN STAPLETON
No, I haven’t seen any fluid on the ground. I also checked the dip stick and saw that it wasn’t losing any fluid.
Jan 29, 2022 at 10:56 AM
SQM
  • 6,383 POSTS
Just keep an eye on it and check the fluid from time to time.
But odds are it is not an active leak or a very minor leak that is not impacting the fluid level that can be measured.
Jan 29, 2022 at 11:04 AM
