Is it possible to manually flip a blend door actuator?
248,990 MILES • 3.4L • 4 CYL • 2WD • AUTOMATIC
ADAMSPAULA516
Manually flipping the blend door actuator.
Vehicle listed above is an LT AWD SUV.
Mar 3, 2022 at 1:53 PM
SQM
  • 6,383 POSTS
Since the actuator actually has a gear, it will require you to turn the gear on the actuator door. The issue is it might not stay in that position. Unless something forces it to stay in a certain position, as soon as the air gets turned on it can switch position.
Here is a helpful guide:
I have attached diagrams for the blend door actuator below.
Mar 3, 2022 at 3:02 PM
