Is it a transmisson problem or electrical problem
180,000 MILES • 3.0L • V6 • AUTOMATIC
SIMONL123
I own a 2000 ford taurus with a 3.0 v6 engine an im having a problem where as the battery light is on an when i goes to drive the car it stall or comes to a stop after a few second maybe minutes of an as i press gass the engine is running but there is no movement
Jan 6, 2015 at 10:46 AM
  • 110,248 POSTS
Is the battery going dead?
Jan 6, 2015 at 9:29 PM
SIMONL123
No the Battery isn't
Jan 7, 2015 at 6:18 AM
  • 110,248 POSTS
Most likely the trans problem is somehow related to the electrical issue. Have you checked to make sure all grounds are clean and tight? Also, are battery terminals clean and tight?
Jan 8, 2015 at 12:32 AM
SIMONL123
Any suggestions on what i sound do
Jan 8, 2015 at 10:35 AM
  • 110,248 POSTS
Do a visual inspection of the battery terminals, the main ground from the battery to the engine block... If everything looks good, Also, you should have the electrical system checked. The battery, alternator... should be inspected. Most parts stores will do it for free.
NOTE: I assume that when it won't move, the engine still revs.
Jan 8, 2015 at 11:10 AM
SIMONL123
Yes the engine revs
Jan 8, 2015 at 11:13 AM
  • 110,248 POSTS
Okay, then the trans isn't engaging. Start by checking electrical connections as I mentioned.
Jan 8, 2015 at 11:18 AM
SIMONL123
Ok thanks for the help
Jan 8, 2015 at 11:20 AM
  • 110,248 POSTS
Glad to help. Let me know what you find and we'll move on from that point.
Jan 8, 2015 at 11:33 AM
