There is coolant leaking in the back of the motor and on the exhaust, could it be a head gasket issue?
129,500 MILES • 4.6L • V8 • 2WD • MANUAL
ZITT
I replaced the plugs, coil packs, fuel injectors and valve cover gaskets, drove 15 miles and noticed it was completely out of coolant. There does not seem to be any oil in the coolant reservoir or any water with oil, but I discovered coolant leaking in the back of the motor and on the exhaust, and it still runs badly.
The car listed above is a GT.
Jan 7, 2024 at 11:46 PM
  • 110,248 POSTS
It could be a gasket issue, but if you are seeing a leak from the rear of the engine, first check to see if it is a heater hose or something different leaking.
Also, when you drive the vehicle, do you notice excessive white smoke from the exhaust? Does the heater work? Take a look through this link and let me know if it helps:
joe
Jan 8, 2024 at 10:40 AM
  • 55,721 POSTS
It could be, the best way to tell is to remove the spark plugs and pressure test the cooling system and then crank the engine over. This will shoot coolant out the spark plug holes of the affected cylinders. These guides can help, stand back when cranking the engine over to avoid contact with the coolant. You can rent a pressure tester from the auto parts store for free or cheap.
https://www.2carpros.com/articles/radiator-pressure-test
and
Please upload videos of the problem so we can see what's going on.
Jan 8, 2024 at 10:41 AM
