traction control turns on?
2017 GMC SIERRA
150,000 MILES • V8 • TURBO • 4WD • AUTOMATIC
RGALVAN661
The traction control will come on once in a while car shakes when driving at higher speeds. Invalid data?
Aug 6, 2023 at 7:50 AM
  • 55,421 POSTS
Yes, this happens when one of the wheel speed sensors is going out, the ABS system should have stored the code though. Please go over this guide to get the code and fix the problem:
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Please go over this guide and get back to us.
Aug 7, 2023 at 5:39 AM
RGALVAN661
Ya, I got a few codes did it not post? I will try add the image again.
Aug 13, 2023 at 8:28 AM
  • 55,421 POSTS
Was this truck in a flood or an accident? It looks like the BCM has gone out, but I would start by checking all fuses with the systems on. This guide can help:
The U0422 code in a 2017 GMC Sierra indicates a problem with the "Invalid Data Received from Body Control Module" or BCP (Body Control Module "B").
The U0401 code is a generic diagnostic trouble code (DTC) that indicates a communication problem between the Engine Control Module (ECM) and the Transmission Control Module (TCM)
Here are the fuse locations so you check run the test and I have included how to change the BCM out as well, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know how it goes.
Aug 14, 2023 at 5:17 AM
RGALVAN661
It has never been in an accident or water damage. the multimedia in the car does act up especially when I’m on the phone using Bluetooth the car seems to always disconnect and reconnect and other little issues of the sort.
Aug 15, 2023 at 8:10 AM
RGALVAN661
Also, is there a reason that all those codes are coming from the EBCM?
Aug 15, 2023 at 8:22 AM
  • 55,421 POSTS
Okay, it looks like the EBCM has gone out, please follow the steps above to fix the problem. Please let us know how it goes.
Aug 16, 2023 at 4:26 AM
