Intrumental cluster malfunction
145,335 MILES • 4 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Hi, the instrumental cluster is malfunctioning. I need to replace it but it needs to be ordered from another country. After searching I could not find the one that has the same part number as mine but they look alike, the one that have the same part number. I was made to understand that it is for diesel engine. I am somehow confused if I am to order it, what could be your advice sir?
Aug 10, 2021 at 12:24 PM
SQM
  • 6,383 POSTS
General rule is when you order a instrument cluster it has to have the exact same part number as the one in the vehicle.
If it is a different part number it will have different wiring connections and different internal calibrations and will not work.
So you will have to order the exact part number that you need.
Hope this clarifies your concern.
https://www.youtube.com/c/2carpros/featured
Let me know of any questions.
Aug 11, 2021 at 4:13 PM
BLESSING EWOBOR
  • 753 POSTS
Thank you very much sir,
Sir, it seems this is applicable to every modules in the vehicle.
Aug 11, 2021 at 5:27 PM
SQM
  • 6,383 POSTS
Yes, as all the different modules have specific design and specifications and you can only replace with the same part number.
Feel free to reach out to us with any questions.
Aug 11, 2021 at 11:11 PM
BLESSING EWOBOR
  • 753 POSTS
Thank you very much.
2CarPros is really good, I have gotten good information from here. Thank you
Aug 12, 2021 at 12:19 AM
SQM
  • 6,383 POSTS
Thank you for your support!
https://www.sitejabber.com/reviews/2carpros.com
Aug 12, 2021 at 12:52 AM
BLESSING EWOBOR
  • 753 POSTS
I should be the one thanking you for your support.
Aug 15, 2021 at 10:42 AM
SQM
  • 6,383 POSTS
Thank you!
Aug 15, 2021 at 11:33 AM
