Interstate driving and hearing a squeal
230,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
UPMM019
  • 217 POSTS
I drove my SUV yesterday for about an hour on the interstate and intermittently I heard a squeal. I assume it is the serpentine belt. However, not sure what would cause this.
Dec 6, 2016 at 12:13 AM
HMAC300
  • 48,601 POSTS
check belt and tensioner, recommended replacement is 60,000 miles. if you used WD40 or any oil on it the belt is completely shot a tool has to be used to measure if worn or not. if still squeaks remove belt start engine see if still there.
Dec 6, 2016 at 4:14 AM
UPMM019
  • 217 POSTS
I failed to mention that my A/C has been acting up since I got it sometimes it work sometimes not. during the summer when it would kick in I would hear this squeal. I never got around to having it looked at it. could what I hear now in the winter be the same ?
Dec 6, 2016 at 4:17 AM
HMAC300
  • 48,601 POSTS
if you have defrost or demist on yes as compressor works until it is below 32 then it does not. it may be the clutch is bad or compressor or both.
Dec 6, 2016 at 5:29 AM
UPMM019
  • 217 POSTS
so let me ask this, if it cools during the summer I.e. after the squeal is that safe to assume the compressor works and its more likely a clutch issue?
Dec 6, 2016 at 5:38 AM
HMAC300
  • 48,601 POSTS
well I do not want to get to technical but yes the clutch may be to close or to far out of adjustment. but in a lot of these cars the clutch is not available separate you have to buy both.
Dec 6, 2016 at 7:10 AM
UPMM019
  • 217 POSTS
what is a ball park for dealer repair?
Dec 6, 2016 at 8:00 AM
HMAC300
  • 48,601 POSTS
no idea, prices vary all over. any garage can do this not only a dealer. beside you should have it checked out it may be something other than what you think it is.
Dec 6, 2016 at 8:16 AM
