1974 International Truck s I have a disel v8 9.0 ltr that ov
1974 INTERNATIONAL TRUCK
85,000 MILES • V8 • 2WD • MANUAL
CFIDAVID
I just changed the water pump on my truck engine and it now over heats and blows air out of the radiator it seems to build air in the cooling system when you crank it or its running and then it over heats it does seem to be pumping water
Jul 22, 2009 at 8:04 AM
MICKEY-D
  • 304 POSTS
I have a question for you, along with some ideas. Why did you change the w/pump, and was the engine overheating before you changed it? Also, did you change the thermostat too? If not, pull it out and take out the center piece with the spring,then put it back in. Slowly, fill the system with water until you can see it, but don't overfill it. Start it up, and let it run, keeping an eye on the water level. as it goes down and you start to see the radiator core, slowly add more water. If this works, you had a stuck t-stat. You might also want to make sure that the fan is not on backwards, it can happen. Good luck, mickey-d.
Nov 30, 2009 at 1:53 PM
