1961 International Truck s need specs for my truck
1961 INTERNATIONAL TRUCK
MYSTICLADY
Engine Mechanical problem
1961 International Truck s 6 cyl Two Wheel Drive Manual not su miles
i need to know what the specs are for my 1952 international L110 pick up truck.it is six cyl.,i need the tune up specs and point gap,spark plug gap.i could not put the yr.1952 on here so i went to the lowest yr.thx
Nov 21, 2009 at 10:22 AM
HMAC300
  • 48,601 POSTS
I don't have specs for a vehicle that old but if you set the points at .017-.020 and timing at 5 degrees BTDC it should get you in the ball park to run well. If you have a dwell meter that would be better, make it 30-34 degrees dwell. Make sure to set the timing with the vacuum line disconnected. The spark plugs of cours should be at .035.
Dec 2, 2009 at 5:02 AM
