1979 International Scout
64,000 MILES • V8 • 4WD • AUTOMATIC
CHADBAKER
My reverse lights stay on while driving. What do I do? They only cut off when I turn the truck off.
Feb 12, 2009 at 11:38 AM
DON OLIVER
  • 101 POSTS
I love my 79 terra. if the lights stay on, the switch is on the tranny. you can unplug it and the light will go off. the switch connects the power and ground side to make the lights work. replace or do without the backup lights. good luck. you have a bullet proof truck except for the weak body. I have plowed snow for 15 years and the original clutch lasted for 25 years. alas, the body died long before the rest of the drivetrain.
Feb 12, 2009 at 11:51 AM
CHADBAKER
Do you know what the switch is called?
YES, very solid truck!
Feb 12, 2009 at 12:10 PM
DON OLIVER
  • 101 POSTS
backup light / neutral start switch if automatic trans. backup light switch if standard
Feb 12, 2009 at 12:18 PM
CHADBAKER
Thank You!
https://images.2carpros.com/forum/automotive_pictures/316984_026_1.jpg
Feb 12, 2009 at 12:27 PM
