1976 International Scout SPEEDOMETER
MARKSWANN
Noises problem
1976 International Scout V8 Four Wheel Drive Automatic
What causes the speedometer to bounce and make a roaring noise at a faster speed
Feb 25, 2010 at 8:41 AM
MARKSWANN
[quote:af5e049ba0="markswann"]Noises problem
What causes the speedometer to bounce and make a roaring noise at a faster speed[/quote:af5e049ba0]
Feb 25, 2010 at 9:04 AM
  • 75,988 POSTS
Inspect the speedo cable both ends at the tranny and on the speedo head-could be kinked/out of alignment on the head side/tranny-Investigate
Feb 25, 2010 at 9:05 AM
JELLYCO
  • 6 POSTS
What rasmataz said. Also if you have cruise control and not worried about using it you can run a cable from your speedo straight to the tranni instead of it first going through the cruise box.
Mar 7, 2010 at 4:54 PM
