1975 International Scout Timing Marks
LJSHERMAN
Engine Mechanical problem
1975 International Scout V8 Four Wheel Drive Automatic
I need to know how to set the timing marks on crank and cam gears when installing a new cam shaft for a 392 V8
Sep 19, 2009 at 3:27 AM
HMAC300
  • 48,601 POSTS
line them up dot to dot, small crank to cam. Bring it up to TDC and as long as the lifters are all the way down on number 1 you should be ok.
Nov 12, 2009 at 6:10 AM
