1972 International Scout Fuel Lines
CKILLER98765
Engine Mechanical problem
1972 International Scout V8 Four Wheel Drive Automatic
Which place do you put the Fuel Line that goes to the Carborator, where do you put it on ther Carborator?
Apr 9, 2010 at 11:34 AM
HMAC300
  • 48,601 POSTS
there should be only one opening for the fuel line and it will be threaded. it is usually on the front and normally on the passenger side of the engine. take the air cleaner off and you should be able to see it.....
Apr 10, 2010 at 9:53 AM
