1971 Other International Models Wont start
1971 INTERNATIONAL
110,231 MILES • V8 • AWD • AUTOMATIC
DREWCROW
the truck turns over but will not fire up, just replaced all plug wires and spark plugs, still wont fire up
Dec 15, 2008 at 4:41 PM
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Dec 15, 2008 at 4:50 PM
