hard starting
137,465 MILES • 3.1L • V6 • FWD • AUTOMATIC
LAVARIO PATTON
  • 8 POSTS
Not all the time but 95% of the time it takes three or more tries to start my vehicle. It does crank however it eventually stops cranking and my doors will unlock as if I am shutting the vehicle off. When i turn the car off my doors unlock. When i try to start it the doors unlock on their own. Sometimes it starts perfectly fine. Most times it gives me this headache. I replaced the pass-lock and ignition, and also had my complete computer system reprogrammed including the BCM. Any suggestions?
Aug 21, 2017 at 4:51 PM
  • 55,766 POSTS
Yes, sounds like the battery is going bad.
Here are a couple of guides to confirm and fix the car:
and
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Make sure both cables are clean and tight.
Cheers, Ken
Aug 22, 2017 at 8:21 AM
