Intermittent Surging
2005 HOLDEN RODEO
246,500 MILES • 2.0L • 6 CYL • RWD • MANUAL
LEXIGIST
Ongoing but intermittent surging, rpm needle wavers 0-1000, sometimes with fuel smell. Had filters cleaned, other than one in fuel tank. Also this week. Sensor replaced in exhaust. Regularly serviced. Sometimes cuts out. Happens when slowing or on low revs
Feb 19, 2016 at 4:57 PM
  • 31,937 POSTS
Get the fuel pressure tested, see it the pressure increases with the fuel pressure regulator vacuum line disconnected, re post your findings for further advice.
Mar 14, 2016 at 9:57 PM
LEXIGIST
At the present time the car is ok - fingers crossed - a sensor in the exhaust was replaced. Thankyou for your response. If the problem reoccurs I will get this done. Thank you.
Mar 15, 2016 at 6:52 PM
  • 31,937 POSTS
OK, thank you for the feed back, feel free to re post at any time.
Mar 15, 2016 at 10:17 PM
