Intermittent starting
140,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CFRALEY
Engine will only start and run with number one plug removed.
Apr 3, 2017 at 1:48 AM
HMAC300
  • 48,601 POSTS
scan and see if you can come up with a security system problem then check fuses under hood with a test light.is there a misfire or any codes?
Apr 3, 2017 at 3:15 AM
CFRALEY
Original post' the engine will start and run as long as the number one spark plug is out of the engine.
It will not start with the plug in it.
Apr 3, 2017 at 4:31 AM
HMAC300
  • 48,601 POSTS
I know what the question was re read my first reply check fuel pressure with a gauge should be 60-66 psi if lower will not run/start. see link.
Also, check distributor cap for cracks. if you take out number it may be cracked at that position and letting it run.
Apr 3, 2017 at 5:07 AM
STEVE W.
  • 15,419 POSTS
What does it do with #1 installed? Not turn over? Turns over but kicks back? Are you getting anything out of #1 with the plug out, like water or a lot of fuel?
Run a comparative compression test and see if your getting the same pressures in all cylinders.
Apr 7, 2017 at 3:09 PM
