Intermittent Stallling. & Nav radio screen reboots
30,000 MILES • 6 CYL • AWD • AUTOMATIC
ASHLIK
2010 Lexus RX350 Base 6 Cyl
Intermittent Stalling & Nav/Radio Screen Restarts
1. Intermittent stalling after start, reverse and after stopping. Car will immediately restart after open/close door. Occurs on turns, straight, or driveway/ incline. Below 20 mph. Any temperature outside
2. Center Navagation/ radio screen restarts after vehicle is OFF. Sometimes the screen will illuminate immediately after vehicle shut off. At times panel will restart itself minutes later. Requires vehicle restart and shut off to turn off screen. This may happen occasionally or 8-10 times in a row. If screen runs, result is a dead battery. Doors can not lock if screen is running. If the car is locked and screen starts itself, car can only be opened manually as the fob can not then unlock vehicle. Battery is a new 7 year battery OEM. No codes are present when scanned.
Jan 14, 2016 at 9:51 PM
HMAC300
  • 48,601 POSTS
for both scan for codes a pro will have to do this. also check fuel pressure with a gauge auto parts rent it and clean throttle plate on both sides and iac hole with choke cleaner. you mayhave to pull off engine cover for this.
Jan 14, 2016 at 10:58 PM
ASHLIK
Thank you! I greatly appreciate your recommendations!
Jan 15, 2016 at 12:07 AM
