randomly surges then stalls. The car fires right back up after it stalls. It is completely random. It does it on the highway, red lights, pulling out if a gas station, turning, idle. It runs and drives fine. But randomly the car starts to lurch (imagine rapidly depressing the gas pedal about 5 times in quick succession) then the RPMs drop and it dies. But if you put it in neutral while coasting after it dies, and turn the key, it fires right up. I've replaced the following parts
Pcv valve
Plugs/wires
Fuel filter
MAF sensor
MAP sensor
Radiator (previous problem)
Alternator (previous problem)
The car will not throw a code. First my problem started as the car would not start. Then I replaced pcv, filter, map, plugs and wires. It Started but would not stay running. After replacing the MAF it would stay running and now I'm to my current position. I'm leaning towards it being either
A. The crank sensor
B. The ICM.
C. COIL packs
I have fuel pressure so I am not sure. I am stumped and the mechanic the car has been with for a month's does not believe it is any of those. Does anyone know of this happening to others? Or have experienced this themselves?
Pcv valve
Plugs/wires
Fuel filter
MAF sensor
MAP sensor
A. The crank sensor
B. The ICM.
C. COIL packs
Mar 28, 2017 at 1:10 PM
