Intermittent stalling issues
73,460 MILES • 3.0L • V6 • 2WD • AUTOMATIC
PISAKI
  • 6 POSTS
Dear 2CarPros,
I am hoping that you can provide me with your expertise in solving my stalling problems.
I have the car listed above. Recently it has been stalling intermittently while I have been slowing down and coming to a stop or while I am waiting at a red light. I have had the following work done but the problem remains:
Cleaned the throttle plate and orifice.
Cleaned the MAF sensor.
Replaced the knock sensor.
Replaced the throttle position sensor.
The check engine light icon does not come on and when the ECM is accessed no problem codes come up.
Any insight into what might be causing this problem would be greatly appreciated.
Thank you so much for and advise that you can give me.
Sincerely,
Bill P.
Apr 16, 2018 at 2:12 AM
HARRY P
  • 2,292 POSTS
Possible causes could be: Clogged PCV Valve; dirty air filter; vacuum leaks. The PCV valve is a $5.00 part and a occasional maintenance item. Try changing it and see if it gets better. If that is not it, it could be a vacuum leak as well. Here is our how-to guide on vacuum leaks: https://www.2carpros.com/articles/how-to-use-an-engine-vacuum-gauge
Start there and let us know how it goes for you.
Apr 16, 2018 at 7:46 AM
PISAKI
  • 6 POSTS
Heyman, thank you very much for taking the time to answer my question. I hope that the problem is a clogged PCV valve which would be an easy fix. If not I will try to find out if there is a vacuum leak somewhere in the engine compartment. The air filter was replaced so I know that this is not the problem.
I will send you a message again after I change out the PCV valve.
Again, thanks for your expertise!
Bill P.
Apr 17, 2018 at 2:23 AM
  • 55,748 POSTS
Cheers, Ken
Apr 19, 2018 at 4:44 AM
PISAKI
  • 6 POSTS
Dear Expertise Staff:
I replaced the PCV valve (which was no good) and did a check, but did not find any vacuum leaks, unfortunately my stalling problems on my Nissan Maxima continue. Any other suggestions would be greatly appreciated. Remember when the PCM is accessed no service codes are presented.
Thank you,
Pisaki
Apr 23, 2018 at 3:08 AM
  • 55,748 POSTS
Can I ask if it seems to do it more after you have been driving for a long time? Also, does the car shake when it is stalling kind of like you have not put the clutch in on a stick shift car?
Is there a chance you can make a video of what it is doing so I can see? You can upload it to the site here.
Please let me know.
Apr 23, 2018 at 5:45 AM
HARRY P
  • 2,292 POSTS
Have you replaced the fuel filter? If not, then try it. At twenty three years old, it definitely would need changing either way.
Apr 23, 2018 at 10:38 PM
PISAKI
  • 6 POSTS
Good Morning Heyman and Ken,
This Maxima has an automatic transmission and it tends to stall after it is fully warmed up and have been driving it around for awhile. It does not shutter when it shuts off, just rpm's heading to zero when slowing down for a stop sign or just waiting on a red light to go green. Sometimes the car feels like it is struggling while I am driving at low speeds in city traffic and then I know that it is going to stall out soon. The fuel filter was changed at 60,000 miles but that was about five years ago, do you still believe that this could be the culprit or needs to be changed?
One last clue that I do not know means anything. The problem began right after there was a strong smell of gasoline after filling up the vehicle last December. This smell tends to come back after filling up the tank although not as bad as the first time. The first mechanic that I took it to thought that I just got some bad gas so I put some dry gas in and ran the tank nearly empty before filling up again. Bringing it back to him later that month he then thought it was something else and began changing out some sensors, etc., even though the check engine light has never come on and accessing the PCM still shows no codes (0505). The only other thing that I can think of is the car has been kind of loud for the past five years or so but has no problem passing the annual state inspection and no mechanic has suggested that I get this fixed.
Thank you both again for all the advise that you are giving me because I am hoping that I can resolve it on my own now because I have put so much money into it and the problem still remains the same.
Pisaki
Apr 24, 2018 at 1:53 AM
HARRY P
  • 2,292 POSTS
Well it is a long shot, but there are many people who believe that when a car sits, and gas is in the tank, that sediment and junk builds up and settles in the bottom of the tank. When you run the tank low, the strainer on the fuel pump and the in-line filter can become clogged up, causing the car to act funny, stall, hesitate, and generally lose power. I highly suggest running a bottle of Seafoam through the tank and changing the filter. I hate to start throwing money at the problem, but at least this will not cost a lot.
Apr 24, 2018 at 3:13 AM
  • 55,748 POSTS
I agree with Heyman and want to add my two cents. Have you done the crankshaft sensor because this will cause the problems as well and it will not trigger a code. so it is tough to tell when the sensor is going bad unless you have an oscilloscope.
Apr 24, 2018 at 4:27 AM
HARRY P
  • 2,292 POSTS
I had that thought too Ken, but when I read that the car had not been driven much and that the tank had been run low, it made me think more about the fuel filter. Crank sensor would be my next guess.
Apr 24, 2018 at 4:33 AM
  • 55,748 POSTS
Well get this bad johnny fixed up :)
Apr 24, 2018 at 4:38 AM
PISAKI
  • 6 POSTS
Heyman and Ken,
Thanks again to both of you for your needed input. I will try a new fuel filter along with the Seafoam additive, you are right at this point it would be a cheap fix if it has a shot to work. Not sure what Seafoam does but I did see it at a AutoZone awhile back.
This Maxima has two crankshaft sensors unfortunately so I guess that I would have to replace both of them. According to my Haynes manual it states that a p0407 and a p0905 code would flash if there was a problem when I access my PCM. Again when I do access it no problems or codes come up. Would there be any way of checking them so that I would know if either one of them were defective? Neither of you think that it could be the EGR valve correct?
I will keep in touch with my progress in solving this perplexing problem.
Pisaki
Apr 24, 2018 at 6:22 AM
  • 55,748 POSTS
Yes, it does have two crankshaft sensors I would replace both of them. Here is a guide to help you see their location and a guide to help you see what you are in for when doing the job:
Check out the diagrams (below).
Cheers, Ken
Apr 25, 2018 at 2:34 AM
PISAKI
  • 6 POSTS
Hi Ken,
Thanks for sending me those image details on how to locate both crankshaft position sensors on my Maxima, I really do appreciate it. Also, your link to the replacement video was very helpful because of the tips that I never would have thought of. The parts are not that expensive so I decided to order both of them and hopefully I will not have too much trouble with getting access to where they are located.
I will let you know at a later date how the installation went and how effective they were in solving my stalling issues.
Pisaki
Apr 26, 2018 at 5:51 AM
  • 55,748 POSTS
Please do. Cheers, Ken
Apr 26, 2018 at 9:14 AM
