Intermittent stalling
20,800 MILES • 1.7L • 4 CYL • 4WD • MANUAL
DOMINIC DK TARPEH
The vehicle starts well from rest when cool but will later stall when the system gets hot atleast after 10 to 20 minutes drive.
Most importantly I want to understand the actual message the diagnosis in the below pictorial is conveying..
Sep 17, 2020 at 7:37 AM
Good afternoon,
Nothing showed up for a picture.
As far as the stalling, did you clean the throttle body? This is very common for this issue.
https://www.2carpros.com/articles/stall-at-idle
Sep 18, 2020 at 4:16 AM
DOMINIC DK TARPEH
Maybe there was an oversight or something went wrong for which was not uploaded, but I am sending it to you right now.
Sep 19, 2020 at 7:36 AM
  • 110,248 POSTS
The things listed above in your pic are general component areas issues. Note that they all identify how many faults are related to a specific component. For example, the ABS system has one fault. When the computer is scanned, you can retrieve specific codes from each of the areas listed that are specific to a problem.
Here is a quick video that shows how it's done:
https://youtu.be/YV3TRZwer8k
If you have that done and provide the specific codes, it will point us in the right direction.
As far as the stalling after warm, a common cause is a faulty crankshaft position sensor. Take a look through this link and let us know if what you experience seems to mirror what is discussed:
In most cases, ignition spark is lost when the sensor reaches a certain temperature. That shuts the engine down.
If you want, here is a link that explains how to test for ignition spark. Check this when it fails to start:
Let us know.
Sep 21, 2020 at 12:40 PM
