Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
98
Engine
Crankshaft
Sensor
Replace/Remove
Intermittent problems staying running
1995 OLDSMOBILE 98
150,000 MILES
LESLIE MACDONALD
MEMBER
1 POST
Just changed the crank sensor and can still having issue but will not talk to scanner.
Mar 4, 2017 at 7:22 AM
HMAC300
Experienced Mechanic
this may be a OBD1.5 which you will have to find a mechanic that has adapter so it can read what the problem is. you can check fuel pressure with a gauge auto parts rent it see link.
Mar 5, 2017 at 12:41 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
