Intermittent no start
150,000 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
RONRIOS
My car will not start it cranks but no start it will run if I press on the accelerator and it will run and drive has fuel pressure. codes are evaporate leak and fuel enable code.
Sep 14, 2016 at 12:32 PM
TY ANDERSON
  • 719 POSTS
Do you have the actual codes (example p0446). If you have the code(s) I could steering you in the right direction.
When you say it has fuel pressure do you know if it has enough fuel pressure? Too little fuel pressure can cause long crank, no start or eventually start symptoms.
How does the engine run when is starts running? Can you drive the vehicle with no issues or is it sluggish/hesitates?
Jul 30, 2020 at 7:17 AM
RONRIOS
Hi, thanks for responding. yes fuel pressure is 46 to 50 lbs when cranking we installed new GM fuel pump and vehicle runs perfect no issues. codes are p0442 p1189 n p1626. thanks again
TY ANDERSON
  • 719 POSTS
Great! So is everything good then or are there any other issues you were concerned with?
