Check engine light is on. Car "coughs" during acceleration. Sometimes, Brake Servo Failure warning light comes on too.
Jul 22, 2021 at 12:13 AM
MASTER ASE TECH
✓Experienced Mechanic
Hi my name is Dan.
Sounds like the engine may have a skip to it. Have you pulled the DTC (diagnostic trouble codes)? Sometimes a code like P0302 would point you to the cylinder which is having the issue to help you narrow down the problem. Sometimes it could be as easy as a spark plug or a coil.
