intermittent ignition failure
136,000 MILES • 4.1L • V6 • 2WD • AUTOMATIC
JUSTJUNE
  • 7 POSTS
Lights come on,no crank. move key (like starting) several times and then starts. I read on a blog(which i can not find)that it is a "antenna coil, the kind that wraps around the ignition core" ? ?
the part you put your key into ?
Jan 12, 2016 at 2:52 PM
HMAC300
  • 48,601 POSTS
try resetting your security system first. if no manual look online
Jan 12, 2016 at 11:39 PM
JUSTJUNE
  • 7 POSTS
Where online would be a nice suggestion. I just acquired this car in August of 2015 . I have no security code. BUT I will get back to you. . later
Jan 15, 2016 at 12:50 AM
HMAC300
  • 48,601 POSTS
you won't have a security code unless you have apro model scanner. type in your car type reset security
Jan 15, 2016 at 1:48 AM
JUSTJUNE
  • 7 POSTS
apro ? is that a brand name ? one of those DB Code readers?
Jan 26, 2016 at 12:22 AM
HMAC300
  • 48,601 POSTS
it's supposed to read a pro it's a typo error. you type in your car on your search engine and look for security reset or reset security system online what type of car you have.
Jan 26, 2016 at 1:28 AM
