Intermittent grinding noise (loud) coming from left front wheel
140,000 MILES • 6.8L • V10 • 4WD • AUTOMATIC
RICK REECE
I removed the 4x4 locking assembly ,found damage to the inner spline and needle bearings. I replaced the assembly, but still have the noise. while apart I noticed the axle seal was out of the housing and can pry the axle up and down easily, not the stub shaft but the axle in the housing? the brakes and rotors are new, It sounds as though the front differential is trying to engage .
Jan 29, 2019 at 3:18 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just a question first. When you noticed the axle damage and the seal out did it look like damage was done to the housing as well? Hope this helps and thanks for using 2CarPros.
Danny-
Jan 29, 2019 at 1:29 PM
