Occasionally the A/C fan will stop blowing. The climate control panel stays lit and you can make changes but nothing happens. After a few minutes the fan will start blowing again and everything works normally.
When the weather is hot the radio stops working if the car is stopped. For instance you have driven for an hour or so and stop for fuel. When you restart the car the radio does not work. The dial is lighted and you can change volume etc but no sound. After driving for ten minutes or so the radio sound will resume.
Jul 2, 2018 at 3:09 PM
