intermittent codes C1611,c1643,, b1493,p0335
167,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SANTA FE 11
  • 13 POSTS
March 09
Fiancé driving car for about 5 miles round trip. Go to store, restart the car after shopping and turns out of parking lot when the traction light appears , she pulls vehicle back in lot , turns car off and then restarts car light goes off.
March 10
Drive is 24 miles each way.
Driving on expressway as I’m accelerating, changing lanes, traction light comes on , goes into limped for a mode 5-10 secs , rpm gauge drops to 0 and stays at 0 for the remainder of drive . Car allows me to proceed and functions normal the remainder of drive. Got to work, turned car off then back on light goes off. Drive home was normal with no problems
At home try to replicate the problem with a test drive for about 30 minutes. Car drives normal. No lights / codes are below.
Codes c1643 dtc -comm time out yaw rate and g sensor.
C1611 dtc-lost communication with ECM
March 11
Cleaned throttle body plate with tb on vehicle with MAF cleaner on rag, did move throttle with hand. Started car to go to work check engine light appears, throws code but drives normal to work . Tried a relearn procedure .started car kept rpms at about 3k rpms for 5 mins for a relearn. Turned car off. No light . No problem driving home from work which is 25 miles . Code that was present.
P0106 – dtc-map /barometric pressure circuit range performance.
I cleared code and car drives fine until March 15 after about 150 miles
March 15
traction light appears while driving after making a hard turn but didn’t hit nothing. Only driving about 1/4 mile. Throws code b-1493 ocs communication error . Turned car off then restarted car. It was a hard start traction light stayed on returned home after a 1/4 mile. Turn car off wait a min stared car light is off. Drives normal again. Test drive for another 10 mins . Car is normal
Code b-1493 ocs communication error
Although it seemed live data was slow/lagging in my scan tool but it is only a 200 dollar tool. Example : car went from 800 rpm to 2500 by time tool caught up. I was in idle at stop light again.
March 16
Driving 3 miles was waiting at stop light to change , proceed from stop light, car jerks check engine came on a quick second then disappeared but traction light stayed on . Goes into limp mode, rpm gauge not drops to 0 and remains there the whole ride home. Rough idle for the first few mins when at stop lights. Car then begins to drive normal come to a stop light , proceed from stop light car goes back into limp mode for about 4 blocks then goes back to normal. Get home turn car off. Restart car is normal drive for about 30 mins no lights. Codes below appeared
B1493 ocs communication error, c1611 active cooling fan relay
Drove car to dealer about half hour after test drive which is approx. 8 miles no problem
. After keeping car for two days . Dealer said they only spent a half hour with it and was no help and basically related the same info that you can pull up on google when researching the c1611 code about poetically being three problems and said its either the abs system module, which is obsolete now, the computer ecm which he cant get or problem in wiring harness. Basically no help at all asked dealer if i got a reman ecm or abs can they reprogram/relearn . He said they cant/ don’t recommend because it has a vin already burned in it and the car wont run right. But gave me options to buy a new hyundai
Any suggestions ? Thanks in advance
Also,
I did change the crankshaft position sensor and the driver rear wheel speed sensor after code c1260,c1207,c1611 back in August 2020.
Mar 18, 2022 at 7:36 PM
  • 110,248 POSTS
The C1611 is related to can-bus communication between the HECU and the ESP.
The HECU (hydraulic electronic unit) checks the CAN communication lines for normal ESP (electronic stability program) control and sets this code if a PCM message is not received within a predefined time.
Based on your description, I would start by checking wiring. Do me a favor. Take a look at the diagnostics below for testing the relevant wiring. Let me know if you are comfortable doing it.
The ECM is likely available online. There are people that rebuild them and based on your vehicle's VIN number, it is programmed and plug and play when you get it.
Let me know about the wiring.
Mar 19, 2022 at 1:29 PM
SANTA FE 11
  • 13 POSTS
Thank you for the response and some positive outlook that there is hope. I am rusty with electrical diagram but have basic car knowledge. This is perfect timing. I am going to a friend's house today that has a better understanding. I couldn't find electrical diagrams anywhere online for my vehicle and was trying to get something from the dealer, but no luck. any other suggestions/test if the connections are within spec, or would it most likely be the ECM? Any recommendations for the company that sells and reprograms if I need a new one?
Have a good day.
Mar 19, 2022 at 10:08 PM
  • 110,248 POSTS
You are very welcome. As far as additional recommendations are concerned, the aforementioned tests should indicate where the problem is coming from. If there are any additional wiring schematics you would find helpful, let me know.
Take care and let me know what you find.
Mar 20, 2022 at 11:35 AM
SANTA FE 11
  • 13 POSTS
Update:
Approximately 550 miles from last code/ problem
Took car for test drive after brake job went over some speed bumps and basic driving for about 10 mins. went over a speed bump came to a stop sign turned left went down the block approaching stop sign and the engine dies. Turn the car off. I went to start the car cranked a few times then started. Engine light and traction light on, no rpms on gauge and was in limp mode for about ½ a block.
Codes: p0335 local can bus off.
c1611 active cooling fan relay.
Checked fuses, all good.
switched cooling fan relay with window relay and back turned A/C on and fan kicked in both times after a few minute .
28 March 09
March 10
March 11
March 15
March 16
Also,
22
Conducted voltage test with outbreak box from pin 4,5, to 16. read normal 12.3 volts
Conducted ohm test while car was off and asleep between can low and high 61.2 ohms
Conducted voltage test from ground to high can 2.7 v, low was 2.2 and 2.3 v
Tested connector for crank sensor with key on ignition off ground lead on ground battery post/ 12.2 volts, 4.93 volts for signal and 0.1 for ground is this the same test you provided me with? my next step is the PCM connectors
Took for test drive for about 10 mins no problem. However, sitting in front of house at idle for a few mins all of sudden rpms went high then back to normal. Let run for a few mins. raising idle to about 2400 rpms and back down. no problems front reading lights are flickering, do you have any diagram for that?
Should i still disconnect PCM and test for 1 ohm between connectors the ECM and PCM is the one located by battery box correct. (Pic below)
Any other suggestions?
Thanks, in advance.
Mar 28, 2022 at 11:05 PM
  • 110,248 POSTS
By chance, did you notice if any of the other lights were flickering? Also, the ECM is located under the hood. See pic 1 below.
Let me know about the light issue. Pics 2 and 3 below are the wiring schematic for the interior courtesy lamps.
Let me know if this helps.
Mar 29, 2022 at 8:09 AM
SANTA FE 11
  • 13 POSTS
I don't want to damage anything and am rusty with electrical. When testing PCM and connector, do I have to unplug the battery or follow any extra steps before unplugging PCM for the ohms test. what other test can I perform to diagnose or rule out PCM since I performed your other suggested test?
What's the other module on my vehicle that has the resistor? ABS?
also
The only lights flickering were the reading lights. I changed the lights back from led to right bulbs for the reading lights and is not flickering. I just didn't know if that was tied into my problem.
Thanks again for all your help.
Mar 31, 2022 at 5:35 AM
  • 110,248 POSTS
Before disconnecting the PCM or any module, I always recommend disconnecting the battery. When you plan to reinstall the connector, make sure the battery is disconnected as well. Once the PCM is reconnected, then reconnect the battery.
I didn't realize you had LED installed. That was certainly the cause.
Let me know what I can do to help.
Mar 31, 2022 at 10:20 AM
SANTA FE 11
  • 13 POSTS
Update:
Good afternoon.
Do you still recommend testing the connectors at ECM for resistance if I used the breakout box to test for volts and ohms at the dlc. Do you by chance have the wiring diagram for the can line and what other module has the resistor?
if I disconnect my battery. How long do I have to wait after disconnecting the battery? Also, if I disconnect the battery, won't I lose the data stored on ECM? i may be taking it to a shop if I can't figure it out, but that's my last option.
the car now will run fine for a period of time and has shut off at idle in my garage 10 minutes after test driving. starts right back up. no check engine or trouble lights. just code c 1611. cooling fan relay.
tested cooling fan relays high and low, both relays work. turned A/C on after a few minutes. The low cooling fan relay clicked, and the fan was on. switched high and low relays, performed the same test, and it worked.
c 1611, cooling fan relay.
Thanks again.
Apr 3, 2022 at 7:16 AM
  • 110,248 POSTS
As far as disconnecting the battery, yes it will reset the PCM/codes, so it is a good idea to write them down first. Also, you should be okay if you wait a couple of minutes after disconnecting the battery. However, when it is time to reconnect the PCM, make sure the battery is still disconnected. Once the PCM is connected, then reconnect the battery.
If you look below, I uploaded diagnostics for the P0335. The last pic is the only schematic I have for the CAN.
Apr 3, 2022 at 12:11 PM
SANTA FE 11
  • 13 POSTS
Thanks for the diagrams and quick response. I tested with key on the crank sensor harness connector from battery ground and had 4.93 v at signal, .01 at ground and 12.2 v at hot wire. I also tested resistance from battery ground and 2 of the chassis grounds near fuse box by air box both .01.
I will perform the same test from chassis ground tomorrow.
Also, why would the c 1611 say it's a cooling fan relay? When communication is lost, does it throw the code to with any sensor on that connection? First it was the steering angle sensor, then lost communication with ECM. now cooling fan relay.
thanks
Apr 3, 2022 at 1:33 PM
  • 110,248 POSTS
The C1611 isn't for the cooling fan circuit. It is related to a breakdown in communication between the HECU and the PCM/ECM. See the description below.
Apr 3, 2022 at 2:39 PM
SANTA FE 11
  • 13 POSTS
Good morning,
Update: I took my car to a mechanic on April 9th since my time was limited with work and he told me he would look at it, well he got swamped and for whatever reason kept pushing my car off and after calling several times i finally picked my car up on the 18th and took it to a another shop that had high reviews with a good reputation and is said to have high tech engine diagnostic tools with reprogram and etc. They looked at my car and fixed it on the same day. It was my crank sensor that was failing. I did have the OEM one on the passenger seat which i should have installed before taking it in but decided to let them see all the problems so they can diagnosis it with the symptoms i was encountering. Also, they had said the stalling was also due to my intake manifold runner solenoid which i thought was outside the manifold case, but they said they also had to take off the manifold plenum as well to fix something else. The bottom line is my car is running great and I wanted to say thank you for your time and info. i did learn and/or get a refresher on some engine diagnostic especially with the BUS CAN line.
i asked them why my scanner was related to the c1611. It was saying it was the cooling fan relay and they related the same thing you said that it had nothing to do with the cooling fan and it was giving a generic code because it was a less expensive scanner. I thought it was decent but guess not.
Thanks again.
Have a great day.
Apr 21, 2022 at 9:23 PM
  • 110,248 POSTS
Thank you for the update and I'm glad to hear it's fixed.
Take care of yourself and please feel free to come back anytime in the future.
Apr 22, 2022 at 10:45 AM
