Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
Navigator
Warning Lights
Check Engine Light
Intermittent Check Engine Light
1998 LINCOLN NAVIGATOR
173,000 MILES • 4WD • AUTOMATIC
ALTHEACONKLIN
MEMBER
1 POST
Previous P0442 code, gas cap hx, rain (leak=water inside frame), am=rough idle. Driven.
Oct 15, 2021 at 1:03 AM
SQM
Experienced Mechanic
The code P0442 can get triggered for any type of small leak in the EVAP system. From a leaky gas cap to a cracked hose to a bad purge valve.
Here is a helpful guide:
https://www.2carpros.com/articles/evap-system-code-repair
I have attached the trouble shooting steps for that code below. This can help you with the diagnostics.
Images (Click to enlarge)
Oct 15, 2021 at 1:35 AM
Add image or video
Ask a new question
Engine won't start
Air Conditioner — Not Working
