Intermittent BRAKE and VSA Warning Lights?
185,268 MILES • 3.5L • AUTOMATIC
JGONZO2398
  • 375 POSTS
Today, the red BRAKE warning light briefly illuminated for approximately two seconds while driving, then disappeared.
Later, while stopped at a traffic light with my foot on the brake pedal, the red BRAKE light illuminated again, accompanied by both yellow VSA warning indicators (VSA and the triangle with an exclamation mark).
Once I started driving, the BRAKE light disappeared, but the VSA warnings remained illuminated. I turned the engine off and restarted it, which cleared all the warning lights.
Several hours later, while driving home, the warnings returned. The red BRAKE light intermittently turned on and off, while the VSA warnings remained illuminated.
Recent brake maintenance:
* July 7, 2026 (179,321 miles): Brake master cylinder replaced and brake fluid flushed.
* September 7, 2026 (182,103 miles): All brake calipers, pads, and rotors replaced.
The brake fluid reservoir is full, the parking brake is disengaged, and the vehicle appears to brake normally. I haven’t noticed any obvious loss of braking performance.
I scanned the vehicle using my FIXD OBD2 scanner, which reported no trouble codes, although I understand it may not read ABS/VSA-specific codes.
Any guesses on the potential cause? What should I be checking first?
Nov 20, 2026 at 9:52 PM
  • 55,766 POSTS
Yes, we need a CAN scanner to see what the trouble codes might be. Here is a video to help.
https://www.youtube.com/watch?v=InIlnsjOVFA&t
Also, you might want to try disconnecting the fluid level sensor wire to the master cylinder to see if it stops the brake wanting light from coming on, you might have a defective brake fluid level sensor. Please let me know what you find.
Nov 21, 2026 at 10:22 AM
